HI,
I'm in the process of including all my devices back.
I have 3 UBS and 2 of them have 4 DS18B20 probes connected.
All 3 are including with just the following slaves.
I tried excluding and including but not any better.
I seem to remember with a previous Fw that if you didnt have any temp probes connected it wouldn't create the slaves but in this case all three are including without issue but just now temp slaves.
Do I need to enable  them or any ideas how to resolve?
HC2 running 4.120
_f
I don't have temp sensors connected to mine, but can you please check parameter 14? I think you should set it to 0
Jim
    Jim
    Thanks JIm
    Just checked.. Parameter 14 is set to 0 on the master... :-(
    Inclusion of a UBS with temp sensors can take a long time, depending on the number of nodes in your network. Longer than other devices. Last time I tried inclusion, I think it took about 50 seconds. I'd try "soft reconfigure" first. If that doesn't help, reconfigure, but then leave the system alone for at least one minute.
    • 2 years later...
    On 5/5/2017 at 10:45 PM, AutoFrank said:
    HI,
    HC2 running 4.120
    _f
    I have the same issue. And no temp slave. DS18B20 is connected. I tried several times to excluding/including, even reset the UBS, without success
    @AutoFrank have you fixed the problem? I hope yes :)
