Markus99 0
I am new here. Therefore sorry in case my issue was already discussed in the past.
So if so, thanks for information where to navigate
What is my issue?
I am running OpenHab 2 with a bunch of Fibaro Rollershutter 2. I can calibrate all the devices without any issue.
Now I developed an automation rule to open/close the blinds at a certain time. This is working fine so far. But regularly one or the other blind is loosing the its position information.
It is not always the same device. After re-calibration every thing works fine again for a couple of days.
How do I detect this?
User inteface (slider element) shows the wrong information. Retrieving position of rollershutter device tells for example 30% open but blind is opened completely.
Since my rule is depending on the position information (e.g. close only if not already closed for 75%) this is causing some trouble.
I would be happy about any advice what might is wrong in the system.
5 answers to this question
