cashe 8
Hello, everybody!
I stuck in a problem. I tried to setValue for few dimmers simultaneously with no luck.
Initial:
Then I make a loop to set all the values:
What could be simpler? But not as it seems...
Usually, first few dimmers accept "setValue" command and successfully set up. But few last ones set up the desired level with a big lag (2-20 seconds) or even have no reaction at all.
I thought it is because of z-wave network be overloaded within multiple commands were sent during a short period of time. I tried to make some pause between each fibaro:call
But it has no effect also.
I tried to make an acknowledgment mechanism:
It helps - all dimmers eventually set up. But regarding debug screen, a number of attempts were needed for some dimmers to setValue. So time to setValue for all 6 dimmers varies from 3 to 20 seconds.
So the question is there some method available for setting up multiple dimmers (or any other actors) with values. Something like this:
So it will be not a number of sequential commands but one "broadcast command" for example?
Thanks for helping!
7 answers to this question
