VD Sonos player and TTS functionality
Labtec
I am looking for a VD for using Sonos wtih my HC2.............yes I have allready searched several topics but it is very difficult for me to find the
complete solution ;-)
It would be great :-) if someone can post the vib file including a manual, or give me a link/topic where i can download these files. I want to control my Sonos
via HC2 and additional use the TTS functionality with scenes. So far I understand that I must fill in the IP of the Sonos speaker and use poort 1400? in VD.
" to "
Temat został przeniesiony z "
" do "
Hi @Labtec
There are two solutions on this forum that allow you to control your sonos with your HC2
One leverages a Pi (or similar node.js capable device) to run an api that the HC2 can communicate with
I wrote a tutorial on how to setup and leverage -
There is a second solution by @Krikroff . I am not as familiar with this one but you can find details here
Hopefully one of these will work for you ...
_f
  • Thanks, for now I have installed Krikoff V1.0.1 VD and it is working fine, I can control my Sonos Play 1 from
    HC2. Next is the TTS solution, this seems to be more difficult ;-) for what I have read in the topic there is no
    Dutch language.possible?
    Hi @Labtec,
    I use this service
     and they have Dutch. You need to make api_key here
     and then put that api_key in code for Process button on Sonos VD.
    And then you use this code to send TTS message to Sonos speaker:
    Change 128 with ID code of your Sonos VD. You can use local variable instead of string "Dit is een testbericht". I have this code only in one scene that is triggered when global variable ttsMessage change value. In that variable I send message, volume and ID of the Sonos VD on which I want message to be played.
  • Hi Sankotronic,
    Thanks, this is perfect for the next step :-)
  • Everything works fine, next is to play a MP3 file from my NAS to my Sonos Play 1, how can I do this?
  • I use the path settings below but no sound from the Sonos speaker
    -- stream: the file / uri
    stream = "//192.168.1.250\Public\Fibaro MP3\Burglar-alarm-sound.mp3",
    -- source: "local" or "http", "local" is setted by default
    source = "local",
    This is the Original code and works, so I change the stream to my NAS IP and path and change the source.
    stream = "//s3.amazonaws.com/smartapp-media/sonos/bell1.mp3",
    source = "http",
    Edited by Labtec
    @Sankotronic
    Will it be possible to send this to several sonos players at once or do I have to duplicate 9 times to cover my house? :-)
    @tortho ,
    if sonos speakers are grouped then sending message to master speaker will emit message to all speakers in the group. If not grouped then you have to send message to each speaker separately.
    @Sankotronic
    Could you share some code of that "function" that pack and unpack somethings to global variable ? It sounds nice :)
    Greetings :)
    Perhap @Krikroff can help with tips to a few minor problems:
    1. I am not able to change radiochanels - it seems that nr 1&2 is working, but not the rest
    2. I am not able to adhust volume
    Thank,,,
    I use this service
    I PAY FOR INSTALLATION. ;-)
    I can't get it running... is there someone who can install it on my fibaro installation? I'd pay a little fee.... please contact me with PM if you're interested.
    Thanks!
    Dan
    Thank,,,
    it's strange about the volume, information appear in the debug?
    Thanks!
    Dan
    what exactly is the problem? And please, do not pay for it !!!
    @Krikroff because of your help in the other thread, it works perfect now. :-)
    Unfortunately, there is a big delay in the TTS output. It takes nearly 6-7 seconds, until the text is spoken. Is that normal or is there an option to speed that up? It looks strange that my HUE shows me visually that the alarm system is disarmed but the TTS starts many seconds later. ;-)
    actually url path for sonos should be
    JFYI: sonos use x-rincon-mp3radio type for playing http(s) stream and x-file-cifs for playing  a local files
    Hi Guys,
    At first my compliments it is awesome!!!!
    Its installed and almost excellent.
    The text is comming out of my Sonos>>my wife was surprised to hear my message. Chapeau!!
    Music is a different thing the bells are playing no problem, so the device and scenes are good.
    In my case I changed to time in auto>>>> the bell is still ringing.
    I select a file from my network, if I copy the whole path in explorer it will start to play. That means that the permissions shouild be granted on my network they said to me.
    but Sonos show the titlle but no sound at all.
    If I change HTTP in local still no sound but an error message in my Sonos "Can not play .... file acces denied"!!! I gues I must continiung on this route???
    How I can Sonos player giving acces?
    Note: normaly if Sonos plays music it comes from the same drive in the network.
    I am confused orI am overlooking something.
    Your help is appriciated very much
    Sorry, I initially put this in another thread, but think it is more appropriate here:
    First of all, my sincere thanks to @Krikroff for the VD and a great implementation.
    I have just got my Sonos One, and the TTS is working pretty well. I was wondering if I could find out if it is possible to auto resume the music that was playing (e.g. music from Spotify) before the TTS?
    The scene I am using to play the TTS is as follows:
    %% properties
    %% events
    %% globals
    ----------- Local variables ------------------
    local _f=fibaro
    local message = "This is a test message.";
    local sid = 445 -- The Sonos ID
    local duration = 15 -- seconds for the speak
    local volume = 40 -- volume for the Sonos
    local bid = 16 -- activate button on the Sonos Virtual Device. Do not change.
    local volume = tonumber(volume)
    local duration = tonumber(duration)
    ----------- Do not change anything below -----------
    ----------- or at least only the language code -----
    local params = {
         message = message,
         duration = duration, -- 'auto', -- Duration can be: "auto", xx seconds
         language = "en-GB", -- Language: en-GB (This will be in English). Look here for other language codes:
         volume = volume -- Volume
    local _x ={root="x_sonos_object",load=function(b)
    local c=_f:getGlobalValue(b.root)
    if string.len(c)>0 then
         local d=json.decode(c)
         if d and type(d)=="table" then return d
         else _f:debug("Unable to process data, check variable")
         else _f:debug("No data found!")
    end,set=function(b,e,d)
    local f=b:load()
    if f[e] then
         for g,h in pairs(d)do f[e][g]=h
    else f[e]=d
    _f:setGlobal(b.root,json.encode(f))
    end,get=function(b,e)
    local f=b:load()
    if f and type(f)=="table" then
         for g,h in pairs(f) do
         if tostring(g)==tostring(e or"") then return h
    return nil
    end}
    -------- Activate Sonos and speak up  ----------------
    _x:set(tostring(sid), { tts = params })
    _f:call(sid, "pressButton", bid)
     Thank-you!
