Hi Can anyone help me with double click and triple click on relay switches.
I have a relay switch that is being used to control high load lighting circuits, but need to use Scene activation or send dim command for a separate dimmer.
Any help greatly appreciated.
@leighivins,
What switch is it? Did you adjust parameters regarding that switch for triple click?
    Its a double relay switch 2
    I did set the parameters to allow for double and triple switching.
    OK @leighivins, so you have to have there 3 visible slaves. So 2 slaves are a switch control (on/off) and 3rd one is for sending scene. So that one you will use in scenes.
    If you have not there that 3rd slave, please look into Switch 2 settings, if it's not hiden. If it's not there, please make soft-reconfiguration on that Switch.
    Edited by jakub.jezek
    Thanks dude
