Hi
I have the FGS-222  which I use with Smartthings. I have a centre light and downlights connected to it. I have a problem whereby the Downlights sticks and stays on and neither operating a switch or using the smart things app seems to do anything. There is a constant voltage on the connection.
I have tried swapping around the Q1 and Q2 to see if it made a difference, but no, the downlights still stick on.  The downlights operated by a switch will work for a while and then randomly stick. I have also tried swapping S1 and S2 to rule out the switch and also disconnecting the switch and controlling with the app to see if it would make a difference.
I have tried eliminating the relay and just using a switch and the downlights work fine so as far as I can tell the issue is the relay. I believe it is all cabled correctly as it works for a period and then gets stuck.
Can anyone help as I'm running out of options? I can draw out the circuit if required.
Paul
  • 4 weeks later...
I have a very similar problem using the FGS-223 double switch 2.
I'm using it with 4x12W LED downlights on 1st channel and 3xLED bulb pendant lights 2nd channel. It worked fine for a while but now the 2nd channel gets stuck on and wont turn off at all - not with controller and not using the wall switch. Tried changing the channels over and the same channel got suck on with different lights.
It's been suggested that the in-rush might be to high, but I don't understand why that would affect 2nd channel only.
Sounds like that contact set is stuffed if you give the module a smack with a screw driver it may un weld and come good. It doesnt like the load your switching for some reason, has it switched a fault or maybe bad driver?
You  can slave a PDL 16A relay off it is the easiest fix. Ive only had one weld but it had a unrealistic load on it.
Edited by Jamie mccrostie
  • 6 months later...
Same here. In the last few days the 2nd channel of my FGS-223 double switch 2 has been stuck on.
The 1st channel still works perfectly.
The 2nd channel only has 9W load to some LED stair lights which go on automatically every night.
I tried power cycle and resetting to default settings.
Maybe a known hardware issue?
Please try what @Jamie mccrostie suggested.
If you want some background plus possible solutions, I recommend this old topic (started and maintained by me)
Thanks Peter!
Annoyingly, that didnt come up in my search :-(
I agree and after some quick research on Mr Google I came to the same conclusion.
Be wary of small and/or cheap switch mode power supplies!
8 minutes ago, earto said:
I just had the same issue with the 2nd channel of my FGS-223 being stuck on after months of no problems switching my 9W LED stair lights.
I tried power cycling the unit and messing with settings including a re-initialise.
Finally out of desperation, a sharp tap on the back of the unit released the relay.
Initially, I didnt think the in-rush current for these LED lights would be a factor but now I'm not so sure.
There's only 3x 3W LED lights, each one has its own small driver.
After some research, it appears that smaller/cheaper drivers (switched mode power supplies) lack the inrush protection of higher quality drivers.
One article suggests that the inrush current of smaller drivers is typically 40-70A for 1-2 ms (at the worst time/highest point in the phase)!
Yep, that would do it!
Time 5 milliseconds/division. Peak inrush is just more than 50amps for around 1.5milliseconds.
Blue - mains 100V/division:
Peak Yellow - input current 20amps/division
My LED stair lights were already in our house and look like first generation LED lights.
I could make a circuit to limit inrush current but I'll probably just replace them with better units.
In conclusion, be wary of cheap/small drivers for LED lights - especially multiple in the same circuit.
@earto glad it workad & thanks for reporting back.
