lboele 1
The alarm panel seems to delay putting lights on or start a scene via the alarm panel, when there is a alarm detected. However the delay is set to 0 in the delay panel, it will take about 20 seconds to start the scene or put the lights on.
The problem is NOT the connection between the door sensor and the HC2 because the " alarm detected pop up" shows up immediately when the door is opened.
Someone with the same problem? (and I hope a proper solution!)
5 answers to this question
