Stop all running instances except the last started
FJW
Is there a methode to stop all instances of a scene EXCEPT the last started.
I tried fibaro:abort() but that stops only the last started instance and leaves all other running.
Thanks.
9 answers to this question
Hi @FJW,
Assuming your scene goes to some sort of loop, maybe you can use that loop to monitor a global variable?
J
  • Hi 3JL,
    No, I'm not using loops, I'm trying to keep it as simple as possible (if I can).
    I have a lighting sceme that I want to use to do all of my lighting needs in the house. I use "sleep" to wait until another lamp should turn on.
    The type of lighting is dictated through a variable and the variable in turn is controled by a light sensor.
    So theoretically it is possible to switch to another lighting when there is still one running and I want the last trigger the onlu one to be running.
    Hi FJW,
    The solution then remains the same:
    Just after sleep you check a global variable that can be edited by another instance of the scence.
    For example, assuming you name the global variable MonitorScene1:
    - at the beginning of your scene script, you increment the value of the MonitorScene1 variable
    - If before and after sleep, the value has increased, you know another scene was initiated and you can abort
    J
    Thanks.
    The only way I have found to reliably keep a more recent instance of a scene is to use a second scene to kill all the current running scene instance and then start a new single instance of the original scene. This may work for you but is not exactly what you asked for.
    I was a bi concerned when I first tried this that it may cause issues as it is a bit odd but it does not appear to cause issues
    the cancel scene calls the original after killing all instances of the original
    Use %%killOtherInstances in the header. Like this:
    I will have to pay more attention. When did they add that?
    Edited by robmac
  • Thanks petergebruers,
    I just tried it and ran into a problem.
    I made a scene to switch of a lamp after 60 sec. (just as a test) after movement was detected so: sensor breached.
    %% killOtherInstances
    %% properties
    103 value
    %% weather
    %% events
    %% globals
    if (
     ( tonumber(fibaro:getValue(103, "value")) > 0 )
    or
    then
      local int aantal = fibaro:countScenes();
      fibaro:debug("Power save count: " .. aantal);
      setTimeout(function() fibaro:call(62, "turnOff"); end, 60000)
      fibaro:debug("Power save count end of the scene!");
    What I noticed is that the lamp (ID 62) never switched off???
    When I used a delay of 5 sec. it worked. That got me thinking.
    After about 10 sec. the sensor goes back to safe and that also is registered by the scene and kill the running one.
    Since that is not the trigger, the scene is not started again and the light will NOT go off.
    What I have to do is make the scene trigger on going safe again (== 0) and than it works.
    Do you know if there is another solution?
    Nice :) that's much easier indeed!
    %% properties
    103 value
    %% weather
    %% events
    %% globals
    if (
    or
    then
    Single lamp with fibaro sensor just use association and parameters.
