I have a Fibaro Wall Plug (FGWPF-102) and a RaspberryPI (using openzwave) and USB Z-wave dongle.
It works fine, but the Wall Plug generates 3 readings I hope someone can help explain.
I have pasted the XML readings for this further down.
  • Why do I have two "Power" readings (one under "Class_Sensor_Multilevel" and one under "Class_Meter") ?
  • What is the "Exporting" reading. It is always False.
I use HomeSeer and i have 2 power measurements. These are:
- Atleast one is current power measurement in Watts
- One is total power consumption in kWh
The other is a alarm for power issues such as over current
