ljoubert 0
I have an cooker and I would like to add a red emergency button to cut off the power. Problem, I cannot use the Fibaro single switch since the maximum amperage is 8A and my stove is about 40A. Is there a way that I can do this? And if I would like to measure the amperage of the stove also?
I found the qubino smart meter that I can add directly in the electric table with the
switch. Is this the best (and only solution?)Thank you very much for your help,
Laurent
