my fibaro Home center is not getting detected by fibaro finder. the device is connected using LAN to the network. eventhough the LAN is connected with internet the LED light for LAN is ON, the LED for internet is not ON.
I hope some of you will help me soon
with regards
Moosa Irshad
4 answers to this question
Do you have any virtual network interfaces turned on? If yes, turn them off and you should be able to see your HC from Fibaro finder, see link to topic below. Otherwise this could be an alternative:
    i didnt have any such devices. I just have fibaro motion sensor and a relay connected and also camera,
    Those virtual network interfaces are not in Fibaro HC, but in your PC. Eg if you use VMWave or from an other virtul machine.
    now everything is fine. My routers ip range was changed from static ip of HC2. now i changed it, and it is working fine
