Hi All,
I bought a beamer elevator and it comes with a 433 MHz module.
I would like to keep this also installed in combination with a Fibaro roller shutter 2.
Now i don't know on witch side i must put the roller shutter, on the side of the beamer or the side of the wallplug?
The 433 MHz is only for backup when fibaro loses contact, and i don't want to complete remove the ceiling.
Thank you very much in advance.
David
Edited by Jaapdeknaap
5 answers to this question
You can connect it as I have shown it in the picture.
But I'm not sure, but I think the COM must also be on the L.
Edited by Reinhold
Id say common will be internally linked inside the controller to neutral.
Edited by Jamie mccrostie
please let us know.. if this solution is working..
    Tomorrow i have the time to check it.
    Result?
