fhermes 0
i have bought two FGS-223 Modules because of there Power Measurement capacity. There are currently two devices connected. The devices change there power consumption during Use. My problem is that this does not shown in the power consumption. i should only see the power consumption if i switch it on.
In Example, my lawnmover needs during charge 50W, conservation charge 2,6W and if it is driving 2,4W. If i switch the power on, the system shows me 2,6W all day, even if it is chargeching. Other Example are my pumpcontroll... it need during pumping 600W and if its in standby just 10W... . the system shows me all over day just 600W.
I have changed for testing Parameter 50 = 1% , Parameter 51 = 10s , Parameter 53 = 0,01kwh but it does not change anything.
Where is my fault? Does anyone should have the same issue ?
Thanks in Advanced
