Hi!
dear Fibaro, can you create a warning message like a
/monthly_2017_07/597250cc6b8ac_1g2tlXA82s1.png.6dc87b329263c38193f472df2c1350a7.png" alt="597250cc6b8ac_1g2tlXA82s1.png.6dc87b329263c38193f472df2c1350a7.png" />
when FIBARO core stop LUA scripts unexpectedly?
[DEBUG] 21:34:27: LAMP: OFF (TIMEOUT)
[DEBUG] 20:15:05: LAMP: OFF (TIMEOUT)
[DEBUG] 20:31:06: LAMP: OFF (TIMEOUT)
[DEBUG] 03:52:00: line 35: unexpected character @ character: 1 0:1 [�] line:
[DEBUG] 03:52:00: �
Thank you.
PS: it's simple while true do script...
" to "
Temat został przeniesiony z "
" do "
Do you mean that you would like a notification in the Notification Center? Or do you want an information like this next to a LUA scene box?
@T.Konopka,
Above error is not caused by user LUA scene and line:35 that error message is referring to is from some script that is part of the HC system. After restarting LUA scene it is working again normally until next occurrence of this error which is in my case very rear.
This is definitely one nasty bug in the HC system. It is nasty because it is very hard to reproduce it and it is very rear so I didn't manage to find out what cause it. I also know that this is old bug because it happened to me on older firmware versions from 4.080 onwards.
Solution would be to remove this bug from the system, but it will be difficult task so probably will never be done. Don't take me wrong, it will not be done because every bug removal requires some resources and resources cost money, so there is always question is it worth it.
Fibaro system don't have any watchdogs that can inform users if any of the looping code stopped working. Adding this feature is nice, but again it requires resources that I don't think Fibaro is willing to invest in this moment to that matter.
@10der,
There is a Watchdog scene on French Fibaro forum that can monitor running scenes and VD main loops. It is not perfect, but it does what it is made for. You can find it on this link:
If you don't have account there you will have to make it and make one post in Newbies - present yourself.
I use this scene for some time now and it works perfect with scenes, but has still some problems with virtual devices reporting that main loop has stopped but is actually working. It can restart stopped scene or VD main loop or just inform you so that is solution you are looking for.
@Sankotronic
You are right. I have the same problem. It is a bug of the system HC2 (  line 35: unexpected character @ character: 1 0:1 [�] line: ).
I have been speculating for a long time that this error comes from JSON decode, because it reads as "there is no character at the beginning of the data and the data is empty". Which makes sense if a http requested timed out or returned no data (although that could be a nil result too). I have checked this with other users and they don't have json.decode in their script. But here is the thing. Maybe they use a type of device that indirectly uses JSON and http. One possible candidate is a Philips Hue bulb. I'm not sure, but it is plausible that the HC talks to the Hue bulb via http and uses JSON decode to parse the result. I don't have such a device. I don't have this error.
@10der how often does that script in post #1 fail? Would you say it is often enough to do an experiment? I'm guessing the script fails either on the "get" or the "call". You could try wrapping them in "pcall" to see if this can catch the error (doesn't always work, the called function might abort the script). If you want to try and you've never used "pcall" before, I'll adapt the script for you.
    2
    ~ fortnightly... pcall is cool... but my question is (irony) should I wrap all my scenes to pcode... ha ha ha
    So why FIBARO guys not make it official on the core level and rethrow exception / etc?
    Hi @petergebruers,
    If you remember we already discussed about this error and I agree with you that it has to do something with JSON decode. This are two different fail messages that I know of:
    and this one that was really caused by bad josn format sent by Netatmo in my Netatmo weather station scene:
    Fibaro is using some LUA code for JSON decode/encode and original code can be found here:
    I hope that I didn't break any rules by writing this. If I did then admins please delete this post immediately. At the moment I don't have time to study deeper this code and find resolution, but I remember that @drboss contacted Fibaro regarding this problem and he get answer that Fibaro team will deal with it and add solution to the next release since they already closed scope for firmware release on 17th February this year. I don't know how much time is left between closing scope and releasing firmware but 4.111 was released on 23th February.
    I remember that on 4.120 release I was writing Netatmo weather station scene and above problem was still present. On 24th April @emielstroeve informed me that scene is failing on above error and that was just before 4.121 beta release. Before upgrading to 4.130 I still did some modification of my code and I added additional checks of received data format in my code and above error did not occur any more but that doesn't mean that Fibaro team repaired it.
    @10der,
    On what firmware was your HC2 when this error happened?
    @Sankotronic as always: thanks for sharing. We keep digging, digging, until it is fixed. Or we until I've lost interest in my case :-D
    • 3 weeks later...
    yeah... today. back to home - no lights...
    [DEBUG] 02:49:00: line 35: unexpected character @ character: 1 0:1 [�] line:
    [DEBUG] 02:49:00: �
    [DEBUG] 02:49:00: �
    Is it one of my scenes that stops on this error? Last one that was stopped on this error was Netatmo weather station scene, but thanks to Netatmo having problems with their servers I resolved that I hope for good.
    Did you try Watchdog scene from French forum? If not, I really recommend it for automatic restarting scenes if stop working. I had some false alarms for virtual devices with version 1.2, so now testing version 1.3
    Thank you! will do!
    • 5 weeks later...
    Today, for the first time, I had a long running script (%% autostart) bark at me:
    So I guess I'm now part of the club? ;)
    • 2 months later...
    I also get the same error on one of my scenes. It is happening about everyday now.
    1
    ¯\_(ツ)_/¯
    I can only suggest two things
    1) re-write scene or double check your code
    2) use code from @Sankotronic
    or something like that
