Hello, forum.
- My problem seems to be in my notification center, where my HCL displays '124'. The problem is, that it shows, but I can't interact with the HCL.
Has anyone got the same problem as me, or have a solution for it, then feel free to comment or DM me.
Best regards
LN
6 answers to this question
Hi @Fanie,
That 124 is not an Error, it's a device with ID 124. Maybe it is some dead device or removed device and mess from it got stucked in unit.
Can you try folowing? Access it via folowing URL http://IP_HCL/fibaro/en/devices/configuration.html?id=124 (e.g. http://10.0.0.10/fibaro/en/devices/configuration.html?id=124).
    I can't access it with the URL.
    I only go to the main pages.
    @Fanie, what do you mean that you can't access the URL? Did you put your gateway's IP?
    If there is a device with ID 124 then the URL has to work.
    There is no device whit an ID 124.?
    I am sorry but I am confused right now.
    Can you post an actual screen shot from your system showing the notification?
    Hi
    It is attached in the first message..
