Nibe Uplink VD
Ros
Hi guys,
Good news for the happy customers of Nibe! I am sharing the code for the Nibe Uplink scene.
  • This scene can get the telemetry from your Nibe Uplink cloud. You would be able to see any parameter available through the Nibe uplink and use this data for your other systems. For example, I am using the outside temperature sensor to control my markize on the terrace and inform night cooling bypass decisions for the HRV.
  • This scene can also post a defined set of parameters to the Nibe Uplink cloud. For example, Fibaro uses the overall house states (Home, Away, Vacation, etc. ) to put the Nibe system into a corresponding mode. I have also tried creating a virtual thermostat VD (Nest-like)  which can be used by Nibe to change the flow temp and switch between heating and cooling.
This scene has to be heavily customized for each user, since there are so many different Nibe products that work with the Uplink cloud. My scene is done for the F1255PC.
So far this code has been used by @perjar, @[email protected] - you guys are welcome to share your versions of the code and any improvements!
Replace XXXXX with your Auth credentials - Please follow the instructions in STEP2  here https://www.marshflattsfarm.org.uk/wordpress/?page_id=3480
Please, look though the code and create the necessary Global Variables.
%% properties
%% autostart
%% globals
local Authorized  = true  --Set to true once you have saved the OAuth data
local access_token
local refresh_token
local JRefresh
local cHM
local http = net.HTTPClient({timeout=5000})
-- if scene is started by autorun and is running in the loop then set selfRun to true
-- else if it is called by another scene like Main scene for time based events then
-- set selfRun to false
local selfRun        = true
-- if above selfRun is set to true then set refresh rate in seconds
local refreshloop       = 300
-- DEBUGGING VARIABLES ---------------------------------------------------
-- setup debugging, true is turned on, false turned off. If set to false
-- only ERROR messages will be shown in debug window
local deBug          = true
-- debug function
function logbug(color, message)
  if deBug then
    for line in message:gmatch("[^\010\013]+") do
      local txt = line:gsub("([\038\060\062])",
        function(c)
          return "&#"..string.byte(c)..";"
        end)
      fibaro:debug(('<span style="color:%s">%s</span>'):format(color,txt))
function UpdateNibeTable ()
  fibaro:setGlobal('NibeParameters', json.encode(NibeParameters))
  logbug('green', 'Table updated')
-- SETUP NIBE ACCOUNT (Please follow the instructions in STEP2  here
local client_id = XXXXX'
local client_secret = 'XXXX'
local redirect_uri = 'https://www.marshflattsfarm.org.uk/nibeuplink/oauth2callback/index.php'
local code = 'XXXX'
local requestAuth = 'grant_type=authorization_code&client_id=' ..client_id..
                         '&client_secret=' ..client_secret..
                         '&code=' ..code..
                         '&redirect_uri=' ..redirect_uri..
                         '&scope=READSYSTEM%20WRITESYSTEM'
--Making sure that only one instance of the scene is running.
if (fibaro:countScenes() > 1) then
  fibaro:abort()
--Main function (looping)
function OAuth(nextFunction)
  if not Authorized then
    http:request('https://api.nibeuplink.com/oauth/token', {
      options={
        headers = {
          ['Content-Type'] = 'application/x-www-form-urlencoded;charset=UTF-8'
        data = requestAuth,
        method = 'POST',
        timeout = 20000
      success = function(Oauth)
        logbug('green', 'Initial authorisation response '..Oauth.status)
        fibaro:setGlobal("NibeOauth", Oauth.data)
        Authorized = true
        fibaro:debug('Variables ok')
      end,
      error = function(error)
        print "Initial Auth ERROR"
        print(error)
  else
    local Oauth = fibaro:getGlobalValue("NibeOauth")
    local JOauth = json.decode(Oauth)
    local refresh_token = JOauth.refresh_token
    local refreshAuth = 'grant_type=refresh_token&client_id=' ..client_id..
                         '&refresh_token=' ..refresh_token
      options={
        headers = {
        data = refreshAuth,
        method = 'POST',
        timeout = 20000
      success = function(Refresh)
          logbug('green', 'Refresh response '..Refresh.status)
          JRefresh = json.decode(Refresh.data)
          access_token = JRefresh.access_token
          refresh_token = JRefresh.refresh_token
          if refresh_token == nil then
            logbug ("red","Error: No Refresh Token Found")
          else
            logbug("green","Refresh token obtained from Nibe")
            fibaro:setGlobal("NibeOauth", Refresh.data)
            NibeParameters = json.decode(fibaro:getGlobalValue("NibeParameters"))
            setTimeout(UpdateNibeTable, 20000)
            ConnectionStatus ()
            CategoryStatus ()
            Parameters ()
            GSHPStatus ()
            GSHPMode ()
      end,
        print "Refresh auth ERROR"
        print(error)
  if selfRun then
    logbug("violet", "Wait "..refreshloop.." seconds for next run")
    setTimeout(OAuth, refreshloop*1000)
-- Checks Nibe Uplink connection
function ConnectionStatus (NextFunction)
http:request('https://api.nibeuplink.com/api/v1/systems/35842', {
      options={
        headers = {
          ['Authorization'] = 'Bearer '..access_token,
        method = 'GET',
        timeout = 5000
      success = function(NibeData)
        local JNibeData = json.decode(NibeData.data)
        cHM = os.date("%H:%M")
        if JNibeData.connectionStatus ~= nil then
          NibeConnectionStatus = JNibeData.connectionStatus..' в '..cHM
          logbug('yellow', JNibeData.connectionStatus)
          fibaro:setGlobal("NibeConnectStatus", NibeConnectionStatus)
          NibeParameters.connectionStatus = NibeConnectionStatus
    end,
        print "Connection status request - ERROR"
        print(error)
-- Updates main parameters as in Service Info/Status
function CategoryStatus (NextFunction)
http:request('https://api.nibeuplink.com/api/v1/systems/35842/serviceinfo/categories/status', {
      options={
        headers = {
        method = 'GET',
        timeout = 5000
        for i = 1, #JNibeData do
          if JNibeData.title == 'outdoor temp.' then
            logbug('yellow',JNibeData.title..' '..JNibeData.rawValue)
            OutsideTemp = tonumber(JNibeData.rawValue)/10
            gui_weather = {id=3, properties={Temperature=OutsideTemp}}
            api.put("/devices", gui_weather)
            logbug("green", "GUI Weather temp updated")
          if JNibeData.rawValue ~= nil then
            NibeParameters[JNibeData.title] = JNibeData.rawValue
    end,
        print "Category status request - ERROR"
        print(error)
-- Get room temperature
function Parameters ()
  http:request('https://api.nibeuplink.com/api/v1/systems/35842/parameters?parameterIds=hot_water_boost', {
      options={
        headers = {
          ['Authorization'] = 'Bearer '..access_token,},
        method = 'GET',
        timeout = 5000
        for i = 1,#JNibeData do
          if JNibeData.title == 'Temporary Lux' then
            logbug('yellow',JNibeData.title..' '..JNibeData.displayValue)
            fibaro:setGlobal("LuxWater", JNibeData.displayValue)
            NibeParameters[JNibeData.title] = JNibeData.displayValue
    end,
        print "Parameters request - ERROR"
        print(error)
--Set heat pump mode (Home/Vacation)
function GSHPStatus ()
  SmartHomeMode = fibaro:getGlobalValue("GSHPStatus")
  if SmartHomeMode == 'Home'  then body = json.encode({mode="DEFAULT_OPERATION"})
  elseif SmartHomeMode == 'Away'  then body = json.encode({mode="AWAY_FROM_HOME"})
  elseif SmartHomeMode == 'Vacation' then body = json.encode({mode="VACATION"})
    http:request('https://api.nibeuplink.com/api/v1/systems/35842/smarthome/mode', {
      options={
        headers = {
        ['Content-Type'] = 'application/json'},
        data = body,
        method = 'PUT',
        timeout = 5000
      success = function(Response)
      logbug('yellow', 'SmartHome Response '..Response.status)
    end,
        print "GSHPStatus setting - ERROR"
        print(error)
-- Updates Heat Pump Mode (Nil/Heating/Cooling/Hot water)
function GSHPMode (NextFunction)
http:request('https://api.nibeuplink.com/api/v1/systems/35842/status/system', {
      options={
        headers = {
        method = 'GET',
        timeout = 5000
        --fibaro:debug(NibeData.data)
        if fibaro:getGlobalValue("GSHPStatus") == 'Home'
          then
          if (JNibeData[1] == nil) then fibaro:setGlobal('NibeMode', 'Idle')
          elseif (JNibeData[1].image.name == 'Supply') then fibaro:setGlobal('NibeMode', 'Idle')
          elseif (JNibeData[1].image.name == 'Heating') then fibaro:setGlobal('NibeMode', 'Heating')
          elseif (JNibeData[1].image.name == 'Cooling') then fibaro:setGlobal('NibeMode', 'Cooling')
          elseif (JNibeData[1].image.name == 'Drop') then fibaro:setGlobal('NibeMode', 'Hot Water')
        else
          if (JNibeData[2] == nil) then fibaro:setGlobal('NibeMode', 'Idle')
          elseif (JNibeData[2].image.name == 'Heating') then fibaro:setGlobal('NibeMode', 'Heating')
          elseif (JNibeData[2].image.name == 'Cooling') then fibaro:setGlobal('NibeMode', 'Cooling')
          elseif (JNibeData[2].image.name == 'Drop') then fibaro:setGlobal('NibeMode', 'Hot Water')
        Compressor = false
          if JNibeData.image.name == 'Compressor' then
            Compressor = true
            NibeParameters.compressorFrequency = JNibeData.parameters[4].rawValue
        if Compressor == false then  NibeParameters.compressorFrequency = nil end
    end,
        print "GSHPMode request - ERROR"
        print(error)
--Main part launching the loop
OAuth()
Edited by Ros
19 answers to this question
" to "
Temat został przeniesiony z "
" do "
  • Ок. Seems no one has a Nibe...
    I would like to access their API and get just one parameter. I need to start with authentication, which is described like this:
    Users are authenticated via the
     protocol. NIBE Uplink currently supports the Authorization Code Grant flow and the Implicit Grant flow. The Authorization Code Grant flow targets clients which the OAuth 2 specification deems confidential, such as web applications and mobile apps while the Implicit Grant flow is a shorter flow which targets public clients that can't keep the confidentiality of the OAuth credentials, such as browser based JavaScript applications.
    Under no circumstances is the client allowed to process or handle a user's secret login credentials.
    The following URL:s are used for the OAuth 2 requests
    • Authorize endpoint
    • Token endpoint
    Could you guys please point me to the right place to see a similar code? Which code should I use for OAuth2? I have an identifier, a secret  and authorization code... How do I get an access token?
    Edited by Ros
    Hi @Ros,
    Check Netatmo weather station scene since it uses same OAuth 2 authentication system:
    It might be of help to you.
  • Hi guys,
    I've almost gotten this to work. Apparently there is a private api, that does not need oauth2.
    This API works fine via the POSTMAN  plugin in Chrome, but I am unable to achieve the same result in a Fibaro scene? What am I doing wrong? What is the right code for this in LUA?
    This is the request to authorize with API. When I launch this is Postman, I get Status 200.
    POST /LogIn HTTP/1.1
    Host: www.nibeuplink.com
    Cache-Control: no-cache
    Postman-Token: 4def48a9-e5f7-3797-4296-53247897663d
    Content-Type: multipart/form-data; boundary=----WebKitFormBoundary7MA4YWxkTrZu0gW
    ------WebKitFormBoundary7MA4YWxkTrZu0gW
    Content-Disposition: form-data; name="email"
    [email protected]
    Content-Disposition: form-data; name="password"
    mypassword
    ------WebKitFormBoundary7MA4YWxkTrZu0gW--
    This is the code I'm using for this in a Lua Scene. Is this correct? When I launch this, I get status 302... I think the API authorizes me, because I get redirected to the right link.
    local requestAuth = '[email protected]&password=mypassword'
    http:request('https://www.nibeuplink.com/LogIn', {
    options={
    headers = {
      ['Content-Type'] = 'application/x-www-form-urlencoded'
    data = requestAuth,
    method = 'POST',
    timeout = 5000
    success = function(status)
    print(status.status)
         print(status.data)
    end,
    print "ERROR"
    print(error)
    However, then I need to do a second POST to get the variables. And now the API returns trash, like I have not authorised... is there any way to make the API think this request is part of the same session as above?
    local requestVariables = 'hpid=35842&variables=40033'
    http:request('https://www.nibeuplink.com/PrivateAPI/Values', {
    options={
    headers = {
    data = requestVariables,
    method = 'POST',
    timeout = 10000
          print(status)
    end,
    print "ERROR"
    print(error)
    Edited by Ros
  • @Sankotronic
    Thanks man! I've looked into your code for the Netatmo and was able to replicate the OAuth2 part! Now I've got the set of parameters back from the API. I am unable to parse the JSON file...
    What I would like to do is to set a global variable to a displayValue of a specific parameterID.  Can anyone help?
    The data comes in the following format
  • Ok. I've figured out the JSON issue!
    I have a working VD and Scene for the Nibe heat pump products. Fibaro has access to the Nibe telemetry via the public API (oAuth2) and is able to manage the heat pump via IFTTT.
    If anyone has a Nibe heat pump and wants the code - please, feel free to reach out to me!
    On 2017-08-08 at 1:45 PM, mekis_9 said:
    Hi
    I gladly test your Nibe VD and bring feedback to you.
    bump :-)
    I would love to try it. I have just finished building an integration between the HC2 and my Verisure alarm API and was ready to get going with the Nibe API.
    My thinking was to build something in Python and run it on a Raspberry Pi. There is a library for the Nibe API on Github I was thinking of using. But if I can skip that step and call the Nibe API directly from a VD in the HC2 that's even better!
    I tried the Chrome Postman approach just to see if I could get anything back from the API but my call is just returning the login page.
    All in all, I would be happy to run your code, it will save me some time. :-)
    Per
  • 2 hours ago, laurit said:
    Hi
    If you can share the code I can test that on HC2 with Nibe 1245 heatpump.
    Thanks.
     Please, look at the first post in this thread
  • Nibe has moved its online services to TLS 1.2+ on Jan 31 2019.
    I can confirm the scene is still working after this upgrade to the cloud API.
    Edited by Ros
    Hi @Ros ,
    Thanks for your great work on this Scene!
    I have a F1155PC which is basically the same as the F1255 you have (just without the internal boiler)
    I tried your code and it seems to work partially, although i get an error running the scene.
    /monthly_2021_05/NibeScene.JPG.f06f3168b8d2dd50cdca35c1939c18f2.JPG" />
    Can you help me to get this to work please?
    In your posts you talk about a VD, would you be so kind to share it too?
    Thanks again,
    Remi
