simple powershell script
Hi!
sometimes I'm  lazy :)
I want to turn on/off some devices without FIBARO UI / Mobile or Lili (particularly during Friday Shabbat :) :) :) )
I want to share with you, may be, useless script... but...
so. here is simple powershell script for Windows desktop shortcut.
you can run it
powershell -File fibaro.ps1 5  turnOn
powershell -File fibaro.ps1 5 turnOff
where 5 is device id, turnOn / turnOff - command for a switcher
powershell -File fibaro.ps1 544 50
where 544 is device id,  50 (or any) - level for a dimmer
also, you can trigger state... simple skip last param... pass only deviceId
will automatically turn off if on and vice versa.
Have a nice day!
notice:
please change var
$url = "192.168.1.36" - FB HC IP
$user = "[email protected]" - your login to FB HC
$pass= "fb1234567890" your password to FB HC
attached code in a post please save in file fibaro.ps1
Edited by 10der
Since I don't see that your script based on time schedule, so I think it will be much easier to create two bookmarks on browser for turn on and off
or if your browser already connected you can skip the user:passwd portion
Actually you can create an entire bookmark folder for all devices.
