 here's the v2 din
" to "
Temat został przeniesiony z "
" do "
    Hello again,
    I just test @ggrizliv solution, but seems has some limitation for me.
    1. Switch need to work only as ON/OFF, no toggle.
    2. Switch can't be used in scene activation ( press 1 -  run scene 1, hold....run scene 4 and so on)
    3. Since is a complex circuit can't be modified later...in case new z-wave module come out.....my circuit need indeed many cables but in that case can be edited easier and in case something happen can be used as a normal light switch.
    I was thinking that the backup switch to be same, din rail, and mount them near MCB and Fibaro module, in fuse box, in this case we save cables.
    Attached is my circuit....
    1.Backup switch is normal ON/OFF
    2.Fibaro switch will be toggle to allow scene activation.
    Any ideas?
    Claudiu,
