Jibran 2
I have read many threads and comments about the FIBARO relay that it does not bear the load of LEDS because of high inrush current .
Then i tried to connect a Dimmer 2 with the non dimmable leds. As i have read the parameters of the dimmer 2 that it can detect which is dimmable or non dimmable.
I have found the following results.
1. Without Neutral wire :
When the Dimmer 2 is connected without the N wire, it unable to detect the non dimmable led or light. its simply does not work. Light starts flickering badly. So i disconnected it.
2. With Neutral wire :
When dimmer 2 is connected the the N wire, It successfully detects the non dimmable light or led. For confirmation, I check the parameter of the dimmer , it also detect the load as Non dimmable. Then I changed another parameter of the dimmer , Which force it to only TURN ON and OFF ( NO DIMMING ). It is working but with a little problem.
Problem:
Sometimes when the lights are off, even when there is no electricity, some leds started to flicker slightly like Flashing. After some time it goes off.
Please can anybody tell me what drives them crazy ?
Thankyou
18 answers to this question
