andyp 6
In the last 24 hours I have had 3 devices behave strangely. Two Fibaro relays and a Greenwave power node. When turning them on or off they go into a state of turning on and off constantly . I've rebooted the HC2. I've soft reconfigured them to no avail. I eventually removed the light bulb in one room and unplugged to Power Node . Any suggestions. I've done no changes to the system in days
Found the issue - looked for the common factor - turned out all the devices were running block scenes. and set to change to opposite state. somehow the trigger on device change was set on all 3 devices so it constantly went to opposite state which then triggered the scene to run again and again in vicious loop.
One to watch for but am at a lose to understand how this got set on three devices in same day. Although we did have a power failure in the morning.
