Oriz 0
I'm a new Fibaro user and having some issues here that i wish some one could help me here.
1. I'm having difficulties to install the Fibaro Dimmer 2 .
After i installed it (without N) , turning the switch on/off works only on some cases. Also, swiping the bar on the mobile app causes the light to flicker.
I have a strip LED connected to a 12V. Is this something that should work?
2. In my bed room, i have a box of 2 switches (each one control a separate light).
However, I have another box with only 1 switch that also controls one of the lights.
I have managed to successfully connect Single / Double switches without any problems. Which module should i choose now? Double Switch will be ok? If so, how should i connect it?
Thank you all.
Edited by Oriz31 answers to this question
