ChromeCast play status in HC2/HCL
Tor Magnus
Hi guys,
I've made a little python program that will locate all chromecasts in your network and update a global variable on your fibaro host for each chromecast it finds. You need to create the variable before the script can update it in the format of cc_<chromecast_name> where spaces in the name gets replaced with underscores.
I use this to dim the light in our TV room while content is playing. Because it's using callback from the chromecast it will immediately trigger a change when you pause or play again.
