Get IP Address from MAC Address
Say that I know the MAC address of a specific device I have and I want to retreive the IP Address. How can I retreive it using LUA?
  • Answers 46
  • Created
  • Last Reply
15 minutes ago, AutoFrank said:
@samuel
you could also take a look at the vd code for the network device monitor here
It uses labels to display online/ offline status although it is derived a different way....
i do have this one, but not all devices do have a port, so by arp table is another way to do so.
that's why i was asking
I agree... The ARP approach looks promising for devices that have a permanent IP address (any IP address). It also works if you use DHCP, because devices almost always use the same MAC address. But it still does not work with all phones...
sorry for confusing the issue @samuel, I wasn't suggesting that you use the solution but you could possibly look through the code to see how VD lables are updated
ok understand, will take a look at it.
how do i update a table tuble from a json?
jN.lastseen = jN.lastseen + 1
is not working
I guess you did not initialize the field. So your sum would be: nil + 1 and you cannot add to nil. Try this (the if tests. whether the field was initialized) :
if jN.lastseen then
else
  jN.lastseen = 1
If that does not help, please post a bit of code that demonstrates the issue.
