jcdekoning 0
I currently have a single wall switch which is connected to a ceiling lamp. I want to replace this single wall switch with a double one and install a Fibaro Double Switch 2 behind it.
One of the switches will be used to control the lamp at the ceiling, while the second switch will be used as some kind of remote trigger to a lamp which will be not be connected in the same circuit.
Is this possible? Where should Q2 (see image) be connected with? Directly with the neutral lead?
Edited by jcdekoningLink to post
