Why does change the icon of the VD not work ?
Vinisz
Hello everyone,
I have this code
local myDeviceID = fibaro:getSelfId()
local value1 = fibaro:getGlobal('bg_ramendeuren')
fibaro:call(myDeviceID, "setProperty", "ui.Label1.value", value1)
if value1 == "Open" then
  fibaro:call(744, "SetProperty", "currentIcon", 1008)
  else
  fibaro:call(744, "SetProperty", "currentIcon", 1010)
But what I want it to do (change the icon based on the global variable) doesn't work and I have no idea what's wrong.
The code is running within the "main loop" section of a virtual device.
the virtual device only has one label, no buttons.
debugging the main loop gives no errors.
Hope someone can help me out here....
Greetings,
Vincent
" to "
Temat został przeniesiony z "
" do "
Try setProperty instead of SetProperty
fibaro:call(744, "setProperty", "currentIcon", 1008)
fibaro:call(744, "setProperty", "currentIcon", 1010)
  • Damn... I shouldn't do things like this when I'm tired...
    thank you, that worked !
