Button Not working
Copied and modified a scene from web.
It worked a couple of times, and sometimes needed "a break" to work again, now it is dead..
Triggered by device 189 - A Fibaro button..
%% autostart
%% properties
%% weather
%% events
189 CentralSceneEvent
%% globals
if (fibaro:countScenes()>1) then
 fibaro:debug("stop scene-count scene")
 fibaro:abort()
local pressSource = fibaro:getSourceTrigger()["event"]["data"]
if (tostring(pressSource["keyAttribute"]) == "Pressed") then
      fibaro:debug('Pressed 1 time') -- add here your code
    fibaro:call(157, "turnOff")
    fibaro:call(234, "pressButton", "9")
elseif (tostring(pressSource["keyAttribute"]) == "Pressed2") then
      fibaro:debug('Pressed 2 times') -- add here your code
and so on....
Gives the following debug error: (Line 15 is the "local pressSource" above
[DEBUG] 08:54:37: line 15: attempt to index field 'event' (a nil value)
What can be wrong,
Brgds
Tor Harald
" to "
Temat został przeniesiony z "
" do "
if you are speaking about "The Button" then it is a known issue with the devices - but fibaro does not admit it.
Regards.
    Thanks, yes it is "The Button"
    Sent it to their support as well now.
