[SOLVED]Turning off light not as simple
I have a simple Lua script that after no motion (between 2 motion sensors) has been detected for 20 minutes then lights turn off. my script is not working properly the lights keep turning off after a few seconds of the last motion sensor becoming safe. Can someone see what I have done wrong in the script. Thanks!
%% autostart
%% properties
51 value
86 value
%% weather
%% events
%% globals
Day_night
if (
 ( fibaro:getGlobalValue("Day_night") == "Day")
    and  ( tonumber(fibaro:getValue(51, "value")) == 0  and  tonumber(fibaro:getValue(86, "value")) == 0 )
or
then
  setTimeout(function()
        fibaro:call(76, "turnOff");
    fibaro:call(78, "turnOff");
    end, 1200)
Quote
    end, 1200)
1200 is 1.2 seconds (=1200 milliseconds)
20 minutes = (20*60*1000)
Edited by RH_Dreambox
    Thanks thats seems to work better.
    The only issue I seem to be having is when the lights are on and I am moving around in the room (motion sensors in room to trigger lights) the lights will go off then will come back on after about 10 seconds. it only does it sometimes not every time. I think it is something to do with the motion sensors.
    thoughts?
    Here is an example of how to do.
    A timer is required to be reset on every new movement.
    The light is lit, IF the global variable is = Night, AND if any of the two sensors feel motion.
    For each new motion, the timer is restarted.
    Also, note that the motion sensor may have a time lag affecting the total time.
    In my case (Aeon multisensor) parameter 3, I have set to 1 minute which will be added to the total time.
    Timer = 20 min + sensor 1 min = 21 min.
    Hope this helps you.
    All,
    I did simplify RH_Dreambox' code to use with 1 motion sensor and 1 switch:
    %% autostart
    %% properties
    %% weather
    %% events
    %% globals
    38 value
    if (fibaro:countScenes()>1)
      then fibaro:abort()
    local light = 166      -- ID Light switch
    local sensor = 38      -- ID Motion sensor
    local timer = 15       -- Time in minutes
    local counter = timer
    if tonumber(fibaro:getValue(sensor, "value")) > 0
      then
      fibaro:call(light, "turnOn")
      while counter > 0
      do
        counter = counter -1
        fibaro:sleep(60*1000)
          then
          counter = timer
      fibaro:call(light, "turnOff")
    But every time when the counter will be lowered by 1 minute counter = counter -1, there is also a 1 minute sleep fibaro:sleep(60*1000).
    During that sleep, no movements of the motion sensor are detected.
    So the timer never will reset except when there is a move exactly after the 1 minute sleep while checking the condition of the motion sensor.
    Is there a smart way to solve this issue?
    Thanks before hand.
    Edited by Fitchie
    What make and model is your motion sensor? In the manual you should be able to find a parameter to increase the blind (or safe timeout) value to > 1 minute.
    Fibaro Motion Sensor FGMS-001.
    Blind time: 2 seconds (parameter 2)
    Motion cancellation time : 5 seconds (parameter 6)
    I'm using the motion sensors also as alarm actors, so I'm not sure it's a good idea to increase the blind time.
    Please increase p6 to 70 or higher. Sensor still reports motion immediately and it will stay breached, until 70 sec without motion have passed. If it detects motion within 70 seconds, it stays breached and resets that internal timer. The scene checks every 60 seconds so it won't turn off the lights if you keep triggering the sensor, because the sensor reports motion for at least 70 seconds.
    Does this help?
    Hi Peter,
    That's a great idea, but when leaving the house and enabling the built in Fibaro alarm, I've to wait for 70 seconds before all breached motion detectors are safe to arm the system.
    For that reason I did lower parameter 6 to a few seconds.
    Another idea is to lower the timer in the script every second (in stead of every minute):
    %% autostart
    %% properties
    199 value
    %% weather
    %% events
    %% globals
      then fibaro:abort()
    local sensor = 199       -- ID Motion sensor
    local timer = 600        -- Time in seconds
      then
      while counter > 0
      do
        fibaro:sleep(1000)
          then
          counter = timer
    This works as well, but will use some extra resources from the HC2.
    Absolutely. You will have to find a compromise then. Maybe 15-30 seconds. It will save some battery. I recommend to increase sleep to 5 seconds to lower resources...
    The code was originally written for fibaro: sleep in seconds.
    But "amat" would have a very long delay (20 min) so I chose to have minutes instead of seconds.
    Otherwise, there would have been a lot of debug rows as output :-)
    :D
    Good point. It brings up an interesting issue: what are the optimal values for the sleep and the parameters of the sensors? I think no two HA solutions are equal, so I give only a recommendation.
    2 hours ago, Fitchie said:
    Hi Peter,
    %% autostart
    %% properties
    199 value
    %% weather
    %% events
    %% globals
      then fibaro:abort()
      then
      while counter > 0
      do
        fibaro:sleep(1000)
          then
          counter = timer
    Hi Fitchie,
    How did you calculate the time in minutes or seconds in this program ? local timer = 600(seconds) or local timer = 20(minutes)? How the Timer variable will know the time in seconds or in minutes ?
    Thankyou
    Hi Jibran,
    You have 2 options:
    - timer in seconds
    fibaro:sleep(1000)
    - timer in minutes
    local timer = 10         -- Time in minutes
    Implementing the 'seconds timer' will take some more system resources from your HC, but then the motion sensor can also be used for alarming purposes.
    Choosing the 'minutes timer' will induce less load on your HC, but as consequence you have to lower the 'blind time' of the motion sensor to >60 seconds.
    Thanks guys these suggestions have helped. I am still trying to learn Lua. In this code below I am trying to tell HC2 to only turn on the lights if I am present (Andy_Present = 1), if it is "Day", if the lux sensor is below 15 and motion is detected. The lights keep coming on everytime motion is detected no matter if it is day or night. No I do not have another scene controlling any of the lights. Can someone help? if you have any suggestions to shorten the code and put less strain on the system please let me know. Thanks in advance!
    %% autostart
    %% properties
    51 value
    86 value
    %% weather
    %% events
    %% globals
    if (fibaro:countScenes()>1) then fibaro:abort() end -- Run only one scene
    local light_1 = 76 -- ID Lamp 1
    local light_2 = 78 -- ID lamp 2
    local sensor_1 = 51 -- Mov. sensor 1
    local sensor_2 = 86 -- Mov. sensor 2
    local timer = 20 -- Timer in minutes
    if (
      (fibaro:getGlobalValue("TimeOfDay") == "Day") and
      (tonumber(fibaro:getValue(sensor_1, "value")) > 0) or (tonumber(fibaro:getValue(sensor_2, "value")) > 0)
        and
        tonumber(fibaro:getGlobalValue("Andy_Present")) == tonumber("1")
    then
      fibaro:debug("Turn on lights")
      fibaro:call(light_1, "setValue", "10")
      fibaro:call(light_2, "setValue", "10")
      while counter > 0
      do
        fibaro:debug("Counter = ".. counter)
        if
        tonumber(fibaro:getValue(sensor_1, "value")) > 0 or tonumber(fibaro:getValue(sensor_2, "value")) > 0
        then
          counter = timer
      fibaro:debug("Turn off lights")
      fibaro:call(light_1, "turnOff")
      fibaro:call(light_2, "turnOff")
    Have some questions:
    what does this do? Present variable?
    why are you getting the average of the Lux?
    I need to tell the system to only do this if the Variable "TimeOfDay" = "Day". I did not see this in the code.
    yes check the variable in the array
    cuz I have 2 (two) sensor in the room and avg is best for me. use min / max if you want it.
    sorry, but if I provide all code what you wanted - you will never learn to develop code in LUA, my IMHO
    On 9/20/2017 at 1:29 PM, 10der said:
    -- check exernal conditions here
    -- can check lux or Day / Night mode / etc
    if (1 == 1) then
    here is should be like a:
    if  ( fibaro:getGlobalValue("Day_night") == "Day")
    instead of
    if (1 == 1)
    Edited by 10der
    Thanks for everyone's input on this. it has been working well over the past few months. I just got some hue bulbs and looking to integrate these bulbs into this scene but having some difficulty doing so. Any assistance would be much appreciated.
    Hi @amatt,
    Check this:
    Everyone,
    I have been running with the code for while now but am getting errors and the scene stops running about once a day now and constantly have to stop it then re-run it.
    I am not sure what the error means. can anyone help? *also I get API errors.
    %% autostart
    %% properties
    %% globals
    -- MAIN SCENE FOR TIME BASED EVENTS CONTROL --
    -- Coded by Sankotronic © 2016
    -- Version 1.1
    This scene will take care of all time based events mostly by changing global
    variables at specified time, but can also be used to call other scenes at
    prefered time or pressing buttons on VDs! Before usage need to configure
    following global variables:
    "HomeTable"       - predefined global variable table with device and scene
                        IDs. Recommended to use since z-wave devices can change
                        their ID with re-inclusion and then is neccesary to edit
                        only scene which make this table and only device ID in
                        scene headers. Much less time and effort is needed than
                        without that option!
    "Darkness"        - global variable, possible values: 0 - Day time,
                        1 - Night time, value is set by this scene
    "AlarmClockStatus" - predefined global variable with values: "On", "Off" -
                        It determines if alarm clock is turned On or Off and
                        value is changed by Alarm Clock VD coded by jompa68 see:
    "PresentState"    - predefined global variable with values: "Home", "Away",
                        "Holiday" - It determines our presence at home. Variable
                        value is changed by three different scenes that are
                        activated manually in my case "Leaving house", "Going on
                        Holidays" and "Returning home"
    "SeasonState"     - predefined global variable with values: "Spring", "Summer",
                        "Autumn", "Winter" - value is set by this scene
    "WeekDay"         - predefined global variable with values: "Sunday", "Monday",
                        "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"
                        - value set by this scene
    "TimeOfDay"       - predefined global variable with values: "Morning", "Day",
                        "Evening", "Night" - value is set by this scene
    "MarginSunrise"   - global variable with possible values from -30 to +30 Min
                        set by virtual device for Sunrise/Sunset - it determines
                        when will Sunrise make changes to the system and can be
                        set from -30 or half hour before real sunrise time to +30
                        or half hour later.
    "MarginSunset"    - global variable with possible values from -30 to +30 Min
                        when will Sunset make changes to the system and can be
                        set from -30 or half hour before real sunset time to +30
                        or half hour later.
    "DemoMode"        - predefined global variable with values: "Yes", "No" -
                        value changed by VD and if set to "Yes" then scene will
                        no more change time based variables like Darkness,
                        TimeOfDay, SeasonState so they can be changed by VD to
                        make test of the system or just demostration
    -- PART FOR USERS TO DEFINE GLOBALS AND STUFF with explanation --------------------
    -- SETUP GLOBAL VARIABLES -- enter names and value mapping of your global variables
    -- or leave as it is
    -- "Darkness" is global variable with two possible states 0 - for day time and 1
    -- for night time and it is changed at sunrise & sunset by main scene that is
    -- responsible for all time based events. See my other posts for details
    local darkness        = "Darkness";
    local darknessMapping = {Light="0", Dark="1"};
    local presentState        = "PresentState";
    local presentStateMapping = {Home="Home", Away="Away", Holiday="Holiday"};
    -- predefined global variable that keeps current day of week.
    local weekDay             = "WeekDay";
    local weekDayMapping      = {Sunday="Nedjelja", Monday="Ponedjeljak", Tuesday="Utorak", Wednesday="Srijeda", Thursday="Četvrtak", Friday="Petak", Saturday="Subota"};
    -- enter week days in your language and mapped in previous variable
    local weekDayMap          = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
    -- predefined global variable that keeps current season
    local seasonState         = "SeasonState";
    local seasonStateMapping  = {Spring="Spring", Summer="Summer", Fall="Fall", Winter="Winter"};
    -- predefined global variable that keeps current time of day
    local timeOfDay           = "TimeOfDay";
    local timeOfDayMapping    = {Morning="Morning", Day="Day", Evening="Evening", Night="Night", Early="Early Morning"};
    --global variables for months
    -- global variables that keep values set by VDs
    local marginSunrise       = "MarginSunrise";
    local marginSunset        = "MarginSunset";
    local marginNight         = "MarginNight"; -- difference for night time
    local nightTime           = "NightTime";
    local marginDay           = "MarginDay"; -- difference for day time
    local dayTime             = "DayTime";
    local monthstate           = "MonthState";
    local deBug        = true;
    local sumDebug     = true;
    -- END OF CODE PART FOR USERS TO EDIT AND SETUP --------------------------
    -- BELLOW CODE NO NEED TO MODIFY BY USER ---------------------------------
    -- function to calculate time by adding or substracting hours and minutes
    function calculateTime(time, DH, DM)
      local H  = tonumber(string.sub(time, 1, 2));
      local M  = tonumber(string.sub(time, 4, 5));
      M = M + DM
      if M >= 60 then
         M = M - 60
         H = H + 1
      elseif M < 0 then
        M = 60 + M
        H = H - 1
      H = H + DH
      if string.len(H) < 2  then H = string.format("%s%s", '0', H) end
      if string.len(M) < 2  then M = string.format("%s%s", '0', M) end
      return string.format("%s:%s", H, M)
    -- function to calculate time by adding hours and minutes
    function calculateTimeString(time, duration)
      local DH = tonumber(string.sub(time, 1, 2));
      local DM = tonumber(string.sub(time, 4, 5));
      M = M + DM
      if M >= 60 then M = M - 60; H = H + 1
      elseif M < 0 then M = 60 + M; H = H - 1; end
      H = H + DH
      if H > 24 then H = H - 24 end
    while true do
      -- get actual time and set up some important variables
      local currenttime  = os.date('*t');
      local currentmonth = currenttime['month']
      local currentday   = currenttime['day']
      local currentwday  = currenttime['wday'];
      local currenthour  = currenttime['hour'];
      local currentmin   = currenttime['min'];
      local TimeCurrent  = os.date("%H:%M", os.time());
      local currentDate  = os.date('*t');
      local earlymorning = "05:00"
      local morning       = "07:00"
      local day             = "10:00"
      local evening         = "17:00"
      local night         = "22:30"
      local sunset       = fibaro:getValue(1, "sunsetHour");
      local sunrise      = fibaro:getValue(1, "sunriseHour");
      local months = {'January', 'February', 'March', 'April', 'May', 'June', 'July', 'August', 'September', 'October', 'November', 'December'};
      -- amount of minutes before/after sunrise value
      local marginRise   = tonumber(fibaro:getGlobalValue(marginSunrise));
      -- amount of minutes before/after sunset value
      local marginSet    = tonumber(fibaro:getGlobalValue(marginSunset));
      -- Calculate sunrise & sunset time in loop so that change of margin is used immediately
      sunrisetime        = calculateTime(sunrise, 0, marginRise)
      sunsettime         = calculateTime(sunset,  0, marginSet)
      if deBug then fibaro:debug("Sunrise time: ".. sunrisetime..", Sunset time: "..sunsettime) end;
      -- Calculate when to change state of TimeOfDay for Day and Night
      dayMargin          = fibaro:getGlobalValue(marginDay);
      daytime            = calculateTimeString(sunrisetime, dayMargin);
                           fibaro:setGlobal(dayTime, daytime);
      nightMargin        = fibaro:getGlobalValue(marginNight);
      nighttime          = calculateTimeString(sunsettime, nightMargin);
                           fibaro:setGlobal(nightTime, nighttime);
        -- check time of day and setup darkness and TimeOfDay global
        -- that affects lights and blinds
        if TimeCurrent >= sunrisetime and TimeCurrent < daytime then
          if deBug then fibaro:debug("Its light outside") end
          fibaro:setGlobal(darkness, darknessMapping.Light)
        elseif TimeCurrent >= daytime and TimeCurrent < sunsettime then
        elseif TimeCurrent >= sunsettime and TimeCurrent < nighttime then
          if deBug then fibaro:debug("Its dark outside") end
          fibaro:setGlobal(darkness, darknessMapping.Dark)
        else
          if deBug then fibaro:debug("Its Dark outside") end
    if TimeCurrent>=earlymorning and TimeCurrent < morning then
        if deBug then fibaro:debug("Between night and morning set TimeOfDay to Early Morning") end
    fibaro:setGlobal(timeOfDay, timeOfDayMapping.Early);
    elseif TimeCurrent>=morning and TimeCurrent < day then
    if deBug then fibaro:debug("Between morning and day set TimeOfDay to Morning") end
    fibaro:setGlobal(timeOfDay, timeOfDayMapping.Morning);
    elseif TimeCurrent>=day and TimeCurrent < evening then
      if deBug then fibaro:debug("Between daytime and evening set TimeOfDay to Day") end
    fibaro:setGlobal(timeOfDay, timeOfDayMapping.Day);
          elseif TimeCurrent>=evening and TimeCurrent < night then
      if deBug then fibaro:debug("Between evening and night set TimeOfDay to Evening") end
          fibaro:setGlobal(timeOfDay, timeOfDayMapping.Evening);
            else
            if deBug then fibaro:debug("Between nighttime and morning set TimeOfDay to Night") end
          fibaro:setGlobal(timeOfDay, timeOfDayMapping.Night);
        fibaro:setGlobal(weekDay, weekDayMap[currentwday]);
        if deBug then fibaro:debug("Day of week is "..weekDayMap[currentwday]) end;
        -- Check time of year and set global for season time
        if (currentmonth >= 1 and currentmonth < 3) then
          if deBug then fibaro:debug("Month is January or february") end;
          fibaro:setGlobal(seasonState, seasonStateMapping.Winter);
        elseif currentmonth == 3 then
         if deBug then fibaro:debug("Month is March") end;
          if currentday < 21 then
          else
            fibaro:setGlobal(seasonState, seasonStateMapping.Spring);
        elseif ( currentmonth >3 and currentmonth < 6) then
          if deBug then fibaro:debug("Month is April or May") end;
        elseif currentmonth == 6 then
          if deBug then fibaro:debug("Month is June") end;
          else
            fibaro:setGlobal(seasonState, seasonStateMapping.Summer);
        elseif  ( currentmonth > 6 and currentmonth < 9) then
          if deBug then fibaro:debug("Month is July or August") end;
        elseif currentmonth == 9 then
          if deBug then fibaro:debug("Month is September") end;
          if currentday < 23 then
          else
            fibaro:setGlobal(seasonState, seasonStateMapping.Fall);
        elseif (currentmonth > 9 and currentmonth < 12) then
          if deBug then fibaro:debug("Month is October or November") end;
        elseif currentmonth == 12 then
          if deBug then fibaro:debug("Month is December") end;
          else
        else
          if deBug then fibaro:debug("Error setting season") end;
        if deBug then fibaro:debug(" Season is "..fibaro:getGlobalValue(seasonState)) end;
      fibaro:setGlobal(monthstate, months[currentmonth]);
      if sumDebug then fibaro:debug("Darkness: " .. fibaro:getGlobalValue(darkness) .. " Sunset: " .. sunset .. " (" .. sunsettime .. ") Sunrise: " .. sunrise .. " (" .. sunrisetime .. ") TimeOfDay: " .. fibaro:getGlobalValue(timeOfDay)) end
      -- Run loop every minute
      fibaro:sleep(59750);
