VD label as scene trigger
Hi guys,
Could anyone please confirm if it is possible to use VD label (e.g. ui.label.value) as a scene trigger? If so, what is the right syntax?
Thanks!
Ros
4 answers to this question
@Ros, do you want to trigger scene after changing VD label's value?
    Exactly
    I don't think so that it is possible.
    If you put the value as a global varible you can use it :)
    Example
    this is a esp 8266 with espeasy on that i use in my setup
