Hello community,
I bought a fibaro wall plug last year and have used it to measure the power consumption of various devices (computer, reading lights, fridge, etc).
Recently, I used it to measure the consumption of the AC unit (about 1000 W) and, while it was still functional, one of the sockets had completely fused with the AC plug, and I had to really pull to separate them.
8150037520479429873%253Faccount_id%253D1
The plug was a type F Schuko, FIBEFGWPF-102, and supposed to be able to handle loads up to 2500W.
I will be returning it since it's still covered by the warranty.
Do you know if the new model (Gen 5) has this issue?
5 answers to this question
Interesting.
Can you please add a photo of the male connector that you used.
Hi @gabaldos
The value 2500 W is not enough to describe energy completely.
There are disclaimers in all
Quote
Power output (for resistive load): 2.5kW at continuous load
and
Quote
In case of loads other than resistive please observe cosφ and, if necessary, use load lower than rated. It is recommended not to exceed 3A for 250 V AC, cosφ=0.4.
AC is rather not a resistive load. It may be resistive only to some extent.
Also, could you post the picture of your AC's rating plate?
" to "
Temat został przeniesiony z "
" do "
    1 hour ago, RH_Dreambox said:
    Interesting.
    I will post a photo when I get home.
    Usually it happens  when you have intermittently (loose-fitted ) connection between male and female connector.
    Please check your connectors  and make sure they are tight.
    See attached illustration (US plug)
