 and translated with google:
Fibaro introduces four new HomeKit products
From
1 September 2017
Fibaro is actually known for its Z-Wave products.
 , the Polish manufacturer for the first time trusted the HomeKit market. In addition to the door and window sensor and the motion detector, Fibaro also published the first Wassermelder with HomeKit Integration. In July, the
 . Now the manufacturer has introduced four more HomeKit products at the IFA in Berlin.
Fibaro Wall Plug
The slim connector can be easily clamped between the consumer and the socket and can then be switched on and off. Just like the competition, the Fibaro WallPlug can also measure the power consumption.
Fibaro Single Switch
The Fibaro Single Switch can be hidden in wall switches and flush mounted boxes. Thus, for example, in the case of lamps with several light bulbs, it is no longer necessary to replace each bulb with a HomeKit-capable, but the flush-mounted module allows control via the light switch.
Fibaro The Button
The button works like a simple switch. Depending on how the button is pressed, up to three different HomeKit scenes can be controlled with one button. The switch is to be available in eight different colors.
Fibaro Radiator Thermostat
For the first time, Fibaro is also fond of heating control. In addition to the Z-Wave version, there will also be a HomeKit version. Like the
 , the Fibaro Radiator Thermostat should replace the radiator thermostat . In contrast to the competition, Fibaro uses a built-in battery. This can be loaded via a USB port. A charge should be sufficient for a complete heating period. The built-in temperature sensor also enables automatic detection of open windows.
At the moment, the information on the individual products is still rather poor. As soon as we know more, we will tell you of course.
Price: 54,00 EUR
Price: 58,90 EUR
Price: 68,46 EUR
Wallplug, switch, button? These are not very new devices I must say..Radiator thermostat would be nice to see, pictures?
Thouse are NOT Z-wave devices, but BLE - Bluetooth Low Energy for Homekit only.
Oh right, my mistake :)
" to "
Temat został przeniesiony z "
" do "
