I want to be able to either :
  • send a http request when a switch is pushed - in order to send a command to a GCE IPX800 relay
or
  • 'push'a virtual device to send the request when a switch is pushed.
I can send a LUA command to the IPX800 and it works.
I did not find how to do the same when a switch is pushed.
I need to do that because the switches are not directly connect to the lights, ...
Thanks a lot for your help.
Pierre
6 answers to this question
the LUA scene you used can be triggered from a switch.
under the %%properties at the top of the scene just add the ID of the switch and the word 'value'
eg switch ID is 22
%%properties
22 value
%%events
%%globals
hope this helps
    I do not use a scene.
    I've 56 switches.
    I don't think it is possible to use so much scenes for ON and OFF.
    What I'd like to do is to either send a http request form the switch programming page or trigger the virtual device form the switch page.
    Best way would be to send http request from the switvch programming page.
    I need to send :
    ON :
    HWS = Net.FHttp("172.17.10.63")
    HWSReponse = HWS:GET("/api/xdevices.json?SetR=15")
    OFF :
    HWSReponse = HWS:GET("/api/xdevices.json?ClearR=15")
    Hi @pierre
    Could I ask what you are looking to do with the http request and why you want it to be triggered from the switch
    as mentioned earlier the switchss are not connect directly to the lights because of the way the cabling was done..
    The lights are connected to relay. In this case EGC IPX800.
    So I need to send a command to the relay when a switch is pushed.
    Switches are only used to send info not to switch on - off the lights.
    Pierrre
    @pierre
    assume switch ID is 22
    %%properties
    22 value
    local sw = fibaro:call(22, 'Value')
    if (sw == '0') then
    PUT LUA CODE HERE FOR OFF
    if (sw == '1') then
    PUT LUA CODE HERE FOR ON
    so if switch in ON position then lights ON and if switch in OFF position then lights OFF
    hope this helps
    I'm not at home so I am a bit limited in resources, but you might be able to do it in one scene. You can put multiple triggers in the header, like:
    22 value
    23 value
    Then use "getSourceTrigger()"  to find out if it was device 22 or 23 that started the scene.
    Edited by petergebruers
