hi,
I made this VD a while ago. It makes a weekly report of the HC2 and works pretty good but I want to move in to a scene.
I used Net.FHttp and this doesnt work in scenes.
Can somebody help?
Regards
Martijn
Edited by I.Srodka
" to "
Temat został przeniesiony z "
" do "
@mdejager
I use this code in a scene to do something similar.
This should help you modify your own code
    thanks. I used api.get too. works perfect.
    I like your function. Which values do you use:
          freeMemRef =;
          sysstoragefree =;
          sysstoragefreeRef =;
          recstoragefreeLimit =;
          cpuPercentageLimit =;
    and why do you check cpu values twice?
