Mo19 1
Hi guys,
I am working on a project in which one of the ceilings has 17 GU 10 LED bulbs in it and the problem, as you probably already can predict, is the brand and wattage of the bulbs themselves. I thingk that it will be a must to sepparate the 17 bulbs into 2 circuits but 1 will have 9 bulbs and the other 8. So, one dimmer 2 for 9 bulbs and one for 8 bulbs... Sounds crazy, right? Even though they will be synchronized there will be some delay for the second Dimmer to react, but that is fine, because that is the only option.
Even if we know the wattage of the LED bulbs we, for sure, do not know their PF, which you can not find even in the manufacturer's website. Fortunately I have 9 LED bulbs - GE, 5.5W, 380lm, 3000k and i will test them and i hope that even if the PF is like 0.5 (I hope it is above) the Dimmer 2 will handle them.
So, any suggestions, tips and tricks are much, much appreciated
6 answers to this question
