Hi!
I've checked it again, my Sonos setup:
And happily song management, skipping, pausing, etc. work just fine.
7 hours ago, swisstoni said:
Aha, I have a Raspberry Pi floating about somewhere, but have never really used it.
Is there a complete zero-to-hero guide on getting this up and running? I'm fairly technical but have zero experience on the pi...
hi
check my youtube channel out for some easy to use guides on setting up raspberry pi
www.youtube.com/yorkshireautomation
    23 hours ago, I.Srodka said:
    Hi!
    Yes - yours is working correctly.... Mine used to look like that (very intermittently).  It seems the built in Fibaro plugin is very buggy.....
    • 4 weeks later...
    On 07/11/2017 at 11:05 PM, I.Srodka said:
    Hi!
    I can also confirm that Sonos plugin is not working - only volume control.  @I.Srodka I would be most interested to see what would happen if you deleted your Sonos device and tried to re-add - I am very confident you will have the same results as everyone else - the Sonos plugin is not working (other than volume control).
    I give up on Sonos plugin long time ago. For all this time I use @Krikroff Sonos remote VD and it works ever since. It also allows you to use TTS service for messaging.
