Hi all. My name is Guido form Italy and i'm happy to join this forum.
I own a Fibaro HC2 and i'm trying to configure a fibaro keyfob. Using the template the hold and 1 click commands work fine, but if I try to add a double click command, the keyfob executes the 1 click one. It seems that the sequence is ignored. Any suggestion? time interval between the clicks?
Thanks in advance
Hi @guido,
Please, try to adjust parameters for keyfob in keyfobs advanced configuration. Then you should be able to create scene with double click via magic scenes or block scenes.
" to "
Temat został przeniesiony z "
" do "
Hi @guido,
i'm using a scene to detect my keyfob...
This simple scene works fine for me :-)
Hi @guido,
Double click is to be set separately (activated) for each button in advanced settings, and please remember to wake up the device after changing the parameters:
Edited by I.Srodka
    On 11/9/2017 at 11:54 AM, jakub.jezek said:
    Hi @guido,
    Thanks!
    I will try this.
    Guido
    On 11/9/2017 at 0:02 PM, I.Srodka said:
    Hi @guido,
    Thanks a lot. are these settings in the advanced tab on the FOB set up?
    Guido
    Edited by guido
    problem solved
    Yes.
    Hi @guido,
    Hi Srodka, sorry but I'm not finding the advanced set up..... Don't understand where are.. In the advanced configuration I've only the possibility to add a parameter... But no preconfigured set up.
    Thanks for your replay.
    Guido
    On 11/9/2017 at 1:08 PM, guido said:
    Thanks!
    I will try this.
    Guido
    Guido
    Problem solved. Keyfob reconfigured!!
    for others that are seeing this have a look at my video, and you can download a template LUA code script aswell.
    thanks
    • 5 years later...
    I'm haveing the same problem um a HC3. I activate the 2 button click parameter and awake the device, but the configuration stays in queue... Had alreayde let it rest for a couple of days and try to wake it up many other times.
    All other features (1 click, hold and release) work fine.
