Help with a trigger based on a delay
Hi all.
I am trying to set up a scene where I get a notification when a device power is under a certain level for a certain period.
Basically the device drops in power to around 1.7W during normal use, but I want to receive a notification when the power is below 5W for longer than 2 minutes, as this tells me it has stopped working.
The notification side etc. is fine, but it is how to (in graphic blocks preferably) say send notification if device power <= 5W for greater than 2 minutes.  I also only want to send this notification once.
Any pointers would be greatly appreciated.
" to "
Temat został przeniesiony z "
" do "
