Fibrao Roller Shutter 2 (FGR222) - calibration issue
Domin2000
Dear community,
i have the following issue with my electric roller shutters. I installed the Fibaro Roller Shutter 2 like in the manual scheme.
Everything is ok. The roller shutters move up and down manualy with zwave. I use FHEM as Software.
The only thing that is not working is the positioning of the roller shutters.
In the manual it is described how to calibrate the fibaro module (shutters should move up, down and then up)
This does not work: :/
With the calibaration command the shutter moves up (LED is flashing green)
After the shutter is in up position, the LED of the Fibaro turns flashing red but the shutter won't come down. It remain in its positon
The S1, S2, Q1 and Q2 are correctly installed otherwise it would not work with software and mechanically with the toggles in the house wall.
My question: Have somebody the same problem with the calibration. Any ideas. Please help!
