Technomorph 0
I am new to HA and Fibaro. I have installed a FGD-212 Dimmer 2 module as a proof of concept. It is controlled via Home Assistant and OpenZWave. The module is wired using 3-wire connection and a toggle switch. Everything is working well so far.
When the light is turned on/off it fades to the target max/min brightness % respectively. Is there a way for the light to go immediately to the min/max target brightness without fading? I have experimented with some of the advanced parameters, but cannot get this to work. I suspect it's possible that OpenZWave may not not be applying settings correctly, however I would be grateful for any suggestions.
Cheers,
TM.
