Technomorph 0
I have just installed a FHS-223 double switch module for a lighting circuit which uses three low-powered LED bulbs. The module has been configured for toggle switches (parameter 20: setting: 1). The issue is that occasionally the module does not respond to the toggle switch changing status, resulting in the switch having to be depressed a second time. In some instances, the module will also not respond at all to the switch status being changed repeatedly for a few seconds. The default setting for parameter 20 (setting 2), seems to elicit the same behaviour. Could this be a faulty module?
Cheers,
TM.
14 answers to this question
