Master/slave documentation of Fibaro devices
Hello everyone!
I've been using Fibaro for some time now and I have to admit that I still do not understand the Z Wave master-slave concept.
I understand that every device has a master which in its turn "talk to" its slave device(s), but where do I find documentation of have many slaves there's suppose to be for different Fibaro devices and what they do? I've tried to find this information in the manuals (manuals.fibaro.com), but can't seam to find it.
This is what the devices looks like in the GUI of the Fibaro HCL:
Fibaro Dimmer 1 (FGD-211)
 - Master
 - Slave
Fibaro Dimmer 2 (FGD-212)
 - Master
 - Slave
 - Slave
 - Slave
Fibaro Single Relay Switch (FGS-211)
 - Master
 - Slave
 - Slave
 - Slave
Fibaro Double Relay Switch (FGS-221)
 - Master
 - Slave
 - Slave
 - Slave
Fibaro RGBW Controller (FGRGBWM) (set up as input/output)
 - Master
 - Slave
 - Slave
 - Slave
 - Slave
 - Slave
 - Slave
What does all these slave devices relate to? Would be very glad to know. Where can I find this information?
Guest kallecux
@A.Socha A silly question: Do you have a small pice of code to differentiate between using central scene or not?
I am a little bit confused.....
Greetings
P.S: Do you mean:
property = "centralSceneEvent",
Edited by kallecux
Yes, for example on HC2
Guest kallecux
Ah @petergebruers thank you!
You have an example for HC3?
In your example you only catch ALL events from device 905.
I think in HC3 it works somthing like this:
Edited by kallecux
Yes, but you can change the header to trigger only on a certain keypress... eg "905 CentralSceneEvent 3 Pressed"
Yes, and if you wanted to catch all scene events, there is a bit of a "hack" to do that.
This triggers on scene event, but only if the event "is not value {}". That effectively matches every keypress because the empty table is not a keypress... A nice "double negation" thingy ;)
Then you can use "sourceTrigger" like on HC2, for example:
prints:
Edited by petergebruers
