[SOLVED]Soft reconfigure shows difference in ID
Now got the ID, it is the ID, shown in the general tab on the master of the device.
Strange however is, that in VD's the ID listed as shown below is to be used. Question now is, which is the ID within the Z-wave network.
I just wanted to get the latest and greatest features of my devices, so I started to soft reconfigure.
I took the one I could easiest live without and/or reconfigure the hard way.
Strange: in the device page, it shows me ID 134 in the information window it shows me ID 133.
Might be related to 1.140 might also not be related to 1.140. I have so far never noticed this difference.
I also did reconfigure with other devices and every time the ID differs by 1 (ID in device page is +1 compared to the ID in the info window)
Scenes however still work with these reconfigured devices.
any clue?
Update: soft reconfigure done with a fibaro relay switch, the difference is 11. Things are getting weird.
Also here when I manually trigger scenes, activating/deactivating the device it all works.
Edited by I.Srodka
" to "
Temat został przeniesiony z "
" do "
@kunoch, that ID 133 is a master device, that represents one physical device. Slaves are devices that provides you control.
E.G. RGBW if set into Out/In mode has 6 slaves, 4 controlable channels (dimmers or sensors) and RGBW and virtual channel if i'm not mistaken.
But, why soft-reconfiguration assigned new ID is mistery even for me. Maybe there were some changes, that resulted into assigning of new IDs.
    @jakub.jezekThanks for the confirmation. I know this master device thing, but I was and still am puzzled which ID is now really the one used for the device. OK, in HCL I do not need these IDs except fro VD usage but then it is scenes, otherwise I can address a (physical) device by its name. I would fully understand, if some sort of a garbage collector is reshuffeling the tables in the background when a (soft) reconfiguraiton is done.
    So far no problem due to the soft reconfiguration with these devices, I was just wondering and still am :/
