I am a new fibaro user.  I bought flood sensor. I have Apple TV gen 4.  I have iPad set as home hub.
When at home both the home app and fibaro app update.  When away from home i receive errors in both apps and they simply show "updating" or "two devices not responding".
Can anyone help me? Thank you
Hi @MF2017,
Does this iPad stays at home connected to the power while you are away from home?
You can also check this Apple Support Article:
Edited by I.Srodka
Use your Apple TV as homekit hub.
    Thank you for reply.  Yes ipad is set up as hub and connected to power and the wifi while away.  I am now setting the Apple TV as the hub following this article
     and i will test the system and report back.  Thanks !
    • 3 months later...
    Hi @MF2017!
    Did you check that solution?
    Do you still have problems?
