[SOLVED][REQUEST] - Enable node/device id mesh reconfig through the api
Hi @T.Konopka, @I.Srodka
I'd like to request the ability to kick off a mesh reconfig on either a device master id or device node id through the api.
I am creating some basic scene to check if a device goes dead. I can wake it up and it would be great to follow that with a mesh reconfg.
A json response with it's success / lack of success would also be helpful.
A stretch would be the list of neighbor nodes that were successfully updated during the process
I think it would be a bad idea to enbable a full mesh reconfig hence the request for a single device / node mesh reconfig
Thanks for considering and comments /amendments welcome
_af
Hello, @AutoFrank :)
I hope that this will help you:
fibaro:call(ID,'requestNodeNeighborUpdate')
but remember to use parentID ;)
    Thanks @T.Konopka
    Parent ID - Is this the same as node id ?
    MasterID from general settings tab :)
    Please, test it and give me feedback.
    will do - thanks
    Hi @T.Konopka
    I tried that and it worked :-)
    The only issue is that there is no feedback as to whether the mesh reconfig failed or succeeded
    If it was an api call , there could be a json response providing this information
    What do you think ?,
    could this be possible  ?
    _af
    The feedback is in the box at the top of BUI.
    I can submit a suggestion to get feedback as a notification or something. :)
    Log for download would be nice. :idea:
    Does it solve your communication issues with that particular device?
    .Thanks @T.Konopka
    I was hoping to use it in a scene or vd and why I looked for it to be exposed through the api so I could capture the api call json response and decide next steps from there within the scene or vd
    Hi @petergebruers
    I didn't have a specific issue I was trying to solve
    I was thinking about developing a vd around this capability but without the api call my idea is sunk :-(
    .. but onto my next project - FitBit :-)
