Figlio 1
Hi all,
I run into a problem with a scene behind a button in a VD I m using to set my living room lights at a certain dim level. I have many buttons each with a different setting of the lights. The problem is i need to run the scene three times to get the lights set at the correct dim level.
In the screenshot below the debug of the thee times i ran the scene are shown.
To start, I manually set the lights at 100% and then turned them all off.
How can i solve this?
Note: I use a MCO Home control pad to manually turn on the light. There is a scene that sets the dim level at 75% when the light is switched on manually. I use the Global SceneStart to determine whether the mco home button is switched on manually or by this scene.
Please find my scene here:
9 answers to this question
