MILANJAIKE 0 Share Posted October 22, 2017 Will time Scheduling works even after the home center 2 or home center lite gets damaged ? Quote Link to post Share on other sites
0 AutoFrank 363 Share Posted October 22, 2017 29 minutes ago, MILANJAIKE said: Will time Scheduling works even after the home center 2 or home center lite gets damaged ? Hi @MILANJAIKE Welcome to the forum... Could you expand on your question ? Quote Link to post Share on other sites
0 MILANJAIKE 0 Author Share Posted October 22, 2017 (edited) I wanted to know that If I install a time scheduled light operation controlled by The Fibaro's hub, home center lite or home center 2 and if the hub gets damaged after some days then will the time scheduler or the time scheduled light still works or not without the help of a hub like home center 2 or home center lite. Edited October 22, 2017 by MILANJAIKE Quote Link to post Share on other sites
0 AutoFrank 363 Share Posted October 22, 2017 22 minutes ago, MILANJAIKE said: I wanted to know that If I install a time scheduled light operation controlled by The Fibaro's hub, home center lite or home center 2 and if the hub gets damaged after some days then will the time scheduler or the time scheduled light still works or not without the help of a hub like home center 2 or home center lite. @MILANJAIKE, Assuming that the schedule is contained in a scene or Virtual device running on the HC2/HCLite and the hub is no longer functional then the answer is No Quote Link to post Share on other sites
0 BOT 0 Share Posted October 24, 2017 The topic has been moved from "FIBARO Portal and Forum policy" to "Home Center 2". Temat został przeniesiony z "FIBARO Portal and Forum policy" do "Home Center 2". Quote Link to post Share on other sites
0 I.Srodka 3 Share Posted October 24, 2017 Hi @MILANJAIKE, Just as @AutoFrank said, our Home Center is the brain of almost all operations. It checks device statuses and conveys to different devices in according to your settings (excluding associations). Only our latest Heat Controller is a bit more advanced in this matter and can work independently for a longer period of time with programmed schedules. Quote Link to post Share on other sites
MILANJAIKE 0
Link to post
5 answers to this question
