[VD] Device Battery Monitor
I added a couple of more battery devices to my setup and decided I needed some type of a battery monitor
This virtual device is triggered to run every 6 hrs (by @Sankotronic Main Scene Scheduler) and checks a set number of Battery powered devices and sends a message if the battery is below 30%
It uses the Smart message Hub to send alerts but could easily be adapted to use email or popup
In addition to the 5 battery devices monitored by this VD, I also have 2 Minimote remotes but since they don't report battery level I couldn't include them
I know there are some excellent scenes and vd's that do this already. I kept mine very simple as this is what suits my needs.
Sharing it as it may be of use to some HC2 owners
Web UI
/monthly_2017_10/bm1.PNG.2348fdc9c90f1e8e1b50d396780c9e99.PNG" />
VD Display
and icon I use
INSTRUCTIONS:
  1. Import the VD
  2. Comment out the HomeTable reference if you don't use one
  3. Amend the list in the devlist table
  4. Amend the battery level reference (line 19)
  5. Amend the messaging medium (line 21 and 29)
  6. Amend the labels as required
and that's it..
Edited by AutoFrank
  • Thanks 5
15 answers to this question
Hi @StefanS
change this line :
to:
Hi AutoFrank,
Can you let me know how it make those Web UI windows, please.
I put one Fibaro Door/Window sensor in my garage door and one switch on/off.
Of course I use the switch to open or close and sensor to know if it open or close, but I have 2 Web UI, and I would like to have only one.
Alex
I got an error:DEBUG] 21:47:10: 211[DEBUG] 21:47:10: DEBUG] 21:47:10: 2
[ERROR] 21:47:10: line getS..."]:21
this line starts with 21:
20        fibaro:call(device, "setProperty", "ui.Label"..i..".value", battLevel.." %")
21       if battLevel < 30 then
What can that be?
with the following code:
E
On 22. 10. 2017 at 10:29 PM, AutoFrank said:
Ahoj,
Přidala jsem do svého zařízení několik baterií a rozhodla jsem se, že potřebuji nějaký typ baterie
Toto virtuální zařízení je spuštěno každých 6 hodin (pomocí programu @Sankotronic Main Scene Scheduler) a kontroluje nastavený počet zařízení napájených z baterie a pošle zprávu, pokud je baterie nižší než 30%
Využívá inteligentní komunikační Hub pro odesílání upozornění, ale může být snadno přizpůsoben pro použití e-mailu nebo popupu
Kromě 5 bateriových zařízení monitorovaných touto VD mám také 2 dálkové ovladače Minimote, ale protože nehlásí stav baterie, nemohl jsem je zahrnout
Vím, že existují nějaké vynikající scény a vd, které to dělají již. Držel jsem se mého velmi jednoduchého, protože to je to, co vyhovuje mým potřebám.
Sdílejte jej, protože to může být užitečné pro některé vlastníky HC2
Webový uživatelský rozhraní
VD displej
a ikonu, kterou používám
INSTRUKCE:
  1. Importujte VD
  2. Komentujte odkaz HomeTable, pokud ji nepoužíváte
  3. Změňte seznam v tabulce devlistů
  4. Změňte stav referenční úrovně baterie (řádek 19)
  5. Změňte médium zasílání zpráv (řádek 21 a 29)
  6. Podle potřeby upravte štítky
a to je vše..
@AutoFrank I'm having the same problem like Gasty. The VD will only show the first device of the table. What could be the problem? Can you give us a hint please?
    On 3/24/2018 at 10:06 PM, StefanS said:
    @AutoFrank Are you still here?
    can you post your code
    thanks
    Thank you for helping me!
    Debug is saying:
    [DEBUG] 19:01:43: 100[
    ERROR] 19:01:43: line getS..."]:16
    Edited by StefanS
    Debug is saying:
    Hi
    The device list cannot be a list of hometable references.
    The code is written to work with a list device id's similar to
    If you have hometable references it get confused by the jT.xxxx.yyy reference as it loops through the devList Table
    It is possible to modify the code to work with a list of hometable references but I haven't had the chance to evolve it to manage this.
    Try changing it to a list of ID's and let me know if it works...
    Same error es before...
    19 minutes ago, domin12 said:
    Hi @StefanS
    change this line :
    to:
    That did the trick :)
    Of course it's not a string. So dumb i didn't see it myself :P
    Thx
    @StefanS , this what You had before with HomeTable was ok .
    You are right. I already tested it also :)
    Edited by StefanS
    Hi @AutoFrank ,
    Could you please move this topic to the Downloads? ;)
    @AutoFrank
     I have been using your VD for a while now and I find it very useful. But I have 1 Danfoss lc13 the battery is almost empty, but he now indicates in the VD that he is 225%. I think this should be 25%. what guest is wrong?
