Roadmap for Zipato Mini RFiD Keypad Support
As of the current version, 4.140, support for this device is unavailable, I'm wondering when will this be available. And by available I understand of having the possibility to sync codes from the HCL to the Zipato controller.
@T.Konopka do you have an ETA for this?
Maybe in a beta firmware?
Edited by abpostelnicu
      any news on this matter?
    +1 on scenes not running upon keypad state change
    On 2.11.2017 at 9:54 AM, abpostelnicu said:
    Also for the alarm system, to arm and disarm the system when i leave/arrive home.
    Would you mind elaborating on how you use the switch and what additional benefit it gives over just using the keypad.
    Thanks.
    Thanks.
    sure the switch when turned on signals the device to beep for an amount of seconds. So when arming/disarming the home you can programme to enable the switch thus beeping for a number of seconds.
    I have just received my Keypad today and I have managed to include it.  It adds master and 2 slaves and rather oddly it is added as a door lock.  The first slave is the lock/unlock and the 2nd slave is open/close.
    The 2nd slave item has a field:
    I have also managed to add RFID Key tags and they do Lock/unlock
    The following likely shows my lack of knowledge.  How do I get it to arm all my PIR's and door contacts please?  If anybody here uses the keypad successfully, could you please post your code here so that we may learn by example
    Many thanks
    L
