HCL time configuration issue - 1970 date
My Hcl is showing the time and date back to 1970 . I have done manual setting and then reboot nothing works.
Also the pool.ntp.org doesn't seem to work as well. It only worked once but after few hours everything comes to the 1.1.1970
Any  help is appreciated
Hi guys,
I'm from Poland and have the same problem with HCL .1.1.1970 and doesn't work with either manual or via Internet. Someone can place a photo of a tile with a localized crystal. Is it really the only way to remove this problem. I have HCL version 4.150 and for a long time I have not been notified about the possibility of updating the software for new ones. How is the latest version for hcl.
Edited by oarman
9 hours ago, oarman said:
Hi guys,
Hi Oarman,
I bought these: https://www.ebay.co.uk/itm/5-X-CRYSTAL-32-768KHZ-12-5PF-SMD-MPN-AB26TRB-32-768KHZ-T-ABRACON/271527836866?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
After changing the crystal to one of these everything works again..
Br
2 godziny temu, Ace02 napisał:
Hi Oarman,
Br
Hi Ace02. thank you. I don't want to make any mistake. Please tell me. Is this item in red.
Yes, thats the one..
Hi Oarman,
There is just one crystal with cylindrical form on the board. It must have a 32768 mark on it.....this is the one - marked in red.
BR
Nick
Edited by nickarsow
On 7/15/2018 at 11:28 PM, Ace02 said:
Hi Zeid, i soldered in a new crystal and everything works again.. So for me it was a hardware problem..
can you confirm its this ?  i got a larger crystal, 8x3mm, i guess existing is 6x2mm, or does means its different frequency ?,
when i opened HCL, i can see crystal has 32c44 on the gold plated cover, is that the smd ? do we need to replace that too ?
Edited by zeid
Hi Zeid,
Confirmed...that's it!
Good afternoon!
Time in HCL is different from time on the computer for 1 hour?
The time zone is correct in both cases.
I'm from Russia, Vladivostok UTC + 10
In the mobile application on Android time is correctly displayed.
L
ASC@ - thx - your solution is great and work correct i used ntp - time.windows.com
W dniu 8.11.2017 o 12:25, I.Srodka napisał:
@DomoAutomation , czy możesz powiedzieć, czy pomógł, czy nie?
@janton , spróbuj zmienić datę na ręczną i ustaw poprawną datę i kliknij przycisk Zapisz.
@severin , spróbuj zrobić to samo.
Jeśli ręczna zmiana daty i zapisanie, a następnie powrót do automatycznego nie pomoże.
Jedynym rozwiązaniem będzie przywrócenie i dodanie urządzeń i scen bez przywracania kopii zapasowej.
Poprawka na ten problem jest już w drodze i będzie dostępna około 4.152 wersji oprogramowania HC.
niestety problem jest nawet już na wersji 4.170 HCL
@Ace02  Hi Ace02 & others involved in solving the issue on the thread,
Could you tell me if the following crystal would be a good replacement as well in addition to your link?
Any help much appreciated.
Thanks,
Paul.
