racerfern 0
I have a Fibaro micro dimmer that works but doesn't play nicely with HS3, Homeseer3. The icons do not display what is really going on and neither do the stats.
I tried excluding and including, I tried re-scanning. Sometimes, the kW works for a few seconds as does the dimming level, then it resorts to junk. Any suggestions as to what to try?
The FW version is 3.4 and I would like to update to 3.5 but I cannot find where to download the update.
Any suggestions would be welcome.
Oct-29 17:55:36 Z-Wave Device: Energy House Front Eaves Power Set to INVALID VALUE
Oct-29 17:55:36 Z-Wave Warning In converting Z-wave data bytes to a value, Size is reported as 2, but length is 1 and is=02
Oct-29 17:55:36 Z-Wave Device: Energy House Front Eaves Power Set to 51.3 (W)
Oct-29 17:55:31 Z-Wave Device: Lighting House Front Eaves Lighting Set to INVALID VALUE
Oct-29 17:55:31 Z-Wave Warning Probable Invalid (MULTILEVEL) Frame Received from Node 27 = 26-03
