I can't connect to my HC in remote, only local (wifi)!
From this morning i can't connect my HC2 in remote from the phone or other device.
My router is ok, HC works fine, everything is good, but i can't access my HC from outside. Only local, in the same wifi.
I try restart with router and HC...
It is a problem with cloud!? Only in my country?
I asked a friend and has the same problem (Romania, too).
Anyone else has the same problem?
@rss, i had the same problem this morning cca at 7:30. Now it seems fine and working.
    Thank you for your feedback.
    Yes, there were some troubles with remote access but it's OK now.
    If you have any further questions please continue in this topic:
    " to "
    Temat został przeniesiony z "
    " do "
